Worcester Greenstar 32 CDi Compact + Hive unit (installation help pls)
13 Dec 2003
UK
Hi I have the Worcester Greenstar 32 CDi Compact with a Worcester Wave unit
I want to change the Wave unit to a Hive, I can't seem to find any simple guides online
any advice / help to install this would be appreciated
the wiring panel looks like this:
I assume that is where the wave is connected to (highlighted in red?)
This is the closest diagram I can find online but not sure:
any help would be appreciated, thanks
The wave is connected to the EMS bus which the hive doesn't use.
You need L & N from the orange plug with two white wires. They go to L & N on the hive receiver. Remove the white wire that goes to the yellow CH connection also.
The yellow CH connection will go to 3 on the Hive receiver. Assuming it's the single channel version. You will also need to put a link on the hive receiver between L & 1.
Any more info needed let me know.
cheers i'll give it a go tomorrow
thanks
Doing the same now,, but I am going to the dual channel ( won't be using it for hot water)
So l,n, and let ch Go to terminal 4
kI38y4K
Do I leave the white loop LRtap to the live
If you have the dual channel hive then why not use the hot water channel to control the WB preheat?
Mick
Oh and tidy that L connection up ;)
Parrot many thanks, this is the only post on the internet that explained exactly what was needed.
Would have to run more/different cable to loop in the hot water
Working a treat, thanks all
