I need to enter text into boxes and then print, to save paper and make life easier how can I produce an A4 page with as many 38 x 30mm bordered boxes on it as possible.
Word allows, a bit of work to do it, but using the tools to print labels should be good for your needs. Basically it's a table, and each cell sized as you set.
Insert a table of 1 row 4 columns. Right click on table and select table properties, in the row tab select row (set to 3.8) select column tab (set to 3)....
If you make narrow margins you should be able to fit 5 boxes across.
Edit: narrow margins and 3cm column width and 3.8cm depth is perfect to fill a page. do it in landscape if you need to.... It fits exactly 6x7 in a grid so 42 boxes a page.
