- 9 Jun 2009
Hi there, I have a problem!
I have installed a free plugin that checks a domain's status to see if its available to buy. It works great and im really pleased with it, theres just one problem. Something in the code of the plugin is reducing the width of my side menu. www.dsm.graphics for refference, the menu should and did stretch across the width of the grey bar, but as you can see it doesnt when the plugin is enabled.
I'm guessing it was the CSS code, i've had a scan through but its all in one big block and I can't find anything that would be causing it. Is there anyone willing to give me a hand? or know somewhere that I can go. I'm willing to pay £10 to get it fixed.
Regards, Dan
Regards, Dan
