Ok so I am currently in process of putting together a build...
I haven't owned a PC for almost 8 years so I have to get EVERYTHING
So far I have bought the majority of the parts with a few bits still outstanding.
I currently have sitting in the babys room...
As you can tell there's a few key items missing...
So this is what I have planned...
Im still not 100% on the monitor as I don't really know what I should be looking for. Chances are with a 980 I wont be doing a great amount of gaming at 1440p, at least not until I saved enough to invest in a 1080.
So what do you guys think? is there anything you suggest I maybe could do differently?
I look forward to hearing your thoughts
Karl.
- 2 x Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £137.99 Bought
- 1 x Super Flower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply - Black= £79.99 Bought
- 1 x Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FB2K2/1= £65.99 Bought
- 1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/= £47.99 Bought
- 1 x Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM001)= £63.95 Bought
- 1 x Phanteks Enthoo Pro Mid Tower Case with Window - White= £89.99 Bought
- 1 x MSI Geforce GTX 980 4GDv OCV1= £269.99 Bought
- 1 x Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail= £229.99
- 1 x Cougar 500M Optical Gaming Mouse - Black= £29.99
- 1 x Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler (CW-9060025-WW)= £109.99
- 3 x be quiet! Silent Wings 3 140mm PWM Fan= £19.99
- 1 x Dell UltraSharp U2515H 25" 2560x1440 IPS Professional Widescreen LED Monitor - Midnight Grey= £275.99
- 1 x Mionix ZIBAL Mechanical Gaming Keyboard MX Black= £52.99
- 1 x Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)= £86.99
Karl.
even then in the heat of summer the house is rarely below 30 degrees.
