work in the rail industry or knows anything: Tech officers/senior Tech officers.
Man of Honour
11 Mar 2004
Hi,
I need to find out exactly what is involved in technical officers and Senior Technical Officers. What they do extra as much detail as pos.
If I can dig out the two job descriptions for both at work tonight, and email you them, would that help?
\Edit: These would be in relation to LUL Technical Officers and Senior Techs only, I don't know much about the BR side of things.
That would be great but what time do you start?
Really need them by about 7pm..
Mikeyboy said:
Don't start till 11pm unfortunately.
Can you send them to me, perhaps I can do some editing tommorow morning. Can you tell me anything about the jobs know?
I've got to fill a question in, on where my future lies within the company and time scales.
Just had a look on the Tube Lines' website, as they're advertising for TO's on the Picc and Jub lines.
Role and Responsibilities:
The purpose of this role is to provide corrective and preventative maintenance cover on all field based signaling equipment used by London Underground including first line telecommunications, lighting and LV Cable call work.
Key Accountabilities:
Undertake and oversee to laid down specification and standards in accordance with trading or contractual agreements, corrective and preventative maintenance, fault rectification, modification and recommissioning on all jobs for which the job holder is licensed.
You will have a direct bearing on the safety and running of the railway.
The job holder will be responsible for all staff under his/her control and others who may be called in to assist.
http://www.tubelines.com/careers/vacancies/200601/TL4236O.aspx
http://www.tubelines.com/careers/vacancies/200601/IRC2271.aspx
Email or give them a call if you need any more info, they should be able to help.
