Work PC
27 Feb 2007
England, Plymouth
Hey all, im doing some security work and have been asked to bring along my own pc, well id rarther build a brand new one and have anywhere between £400 (Sensible budget) to £600.
Not a lot but ive been out of the building scene for about 2 years and came back to find AMD look interesting now! So help needed :)
No monitor needed, would eb nice to overclock it a little but its a work pc s nothing special!
Cheers Shr3k
This is what I would get:
AMD Phenom II X4 955 ~ £122
http://www.overclockers.co.uk/showproduct.php?prodid=cp-244-am
asus m4a785td-v ~ £73
http://www.overclockers.co.uk/showproduct.php?prodid=mb-355-as&groupid=701&catid=5&subcat=1481
has the 785g igp which can run one digital and one analogue monitor at the same time. the motherboard has 128mb of ddr3 for the igp.
8gb 1333mhz ddr3 ~ £168
http://www.overclockers.co.uk/showproduct.php?prodid=my-085-gl&groupid=701&catid=8&subcat=1516
coolermaster elite 334 ~ £28
http://www.overclockers.co.uk/showproduct.php?prodid=ca-184-cm&groupid=701&catid=7&subcat=
samsung spinpoint f3 500gb ~ £41
http://www.overclockers.co.uk/showproduct.php?prodid=hd-081-sa
sata dvd rewriter ~ £17
http://www.overclockers.co.uk/showproduct.php?prodid=cd-038-ot&groupid=701&catid=10&subcat=
corsair cx 400w ~ £39
http://www.overclockers.co.uk/showproduct.php?prodid=ca-017-cs
the psu is made by seasonic.
the total cost is around £488 excluding postage.
the phenom ii x4 955be seems to be ahead of a q9550 in visual studio and java:
http://ixbtlabs.com/articles3/cpu/amd-phenom-2-x4-925-955-p2.html
Comparing the scores with the Core i5 750 in the same applications the Phenom II X4 955BE looks around the same:
http://ixbtlabs.com/articles3/cpu/intel-ci5-660-p2.html
Thanks for the reply, i was extremely impressed with the amd processor the reviews looked amazing
I have nearly the same as you,
I was looking at this motherboard instead as reviews and overclocking looked good, expecially seeming that the chip can go to 3.8 easily:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-210-GI
Thanks
Shr3k
Thanks
Shr3k
The Asus M4A785TD-V has better VRM cooling which will be important in the long term.
If you want a decent aftermarket cooler you should look at this one:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-008-TI
Thanks for your help,
the items arrived this morning and were put together fairly quick,
Temperatures are at arround 22 degrees so extremely happy, going to overclock it tomorrow but soo far compiling and general use have been amazing :)
Thanks again and ill post back the overclocking results
