Working Conditions - Help!
Suspended
22 Oct 2004
I'm currently sat in some darkened room attatched to a data centre, there are no windows, its 32 degrees in here, and to top it all its 100 ft underground with the driest air I've ever experienced.
I need ideas people I'm in here for 3 months 8-5! Are there any recomendatios people could make as to how I can make my little room a bit more bearable?
I'm thinking deskfan and a lamp, but I think a fan will just move the hot air around, I know you can get dehumidifyers, but can you get humidifiers that make the air a bit more moist?
Making the air more humid is just going to make it worse for you, best thing you can do is get a big fan and point it at you, unless you've got somewhere to pipe the hot air out of an air con unit to.
Jokester
Just get some Air-Con clothes;
If that fails, all I can suggest is freezing up some ice-cubes during the night then taking them to work and sticking them behind a fan, help circulate cool air rather than room temperature.
Jokester
Hmmm - I'm basing this air moisture thing on some of my recent travels, Jungle I was fine - thats pretty humid, dessert - I was screwed, air to dry.
I think theres some science behind it though, I'm obviously hotter than the ambient room temperature, so I'm emitting heat into the air, dry air can't transfer heat as efficiently as humid air so I reckon its got to be worth a shot.
Maybe I could put a dehumidifyer at one end and a humidifyer at the other!
Rooms about 20 ft square, I can't see the cieling though, so its either painted black and 6 inches above the lights, or its 100 ft up!
Looks like the Dharma Initiative Logo - Aparently I look a bit like desmond...
What the hell do you do? Work for Dharma?
