"working on it"
12 Apr 2007
Hi,
Both myself and my friend get this issue, we both have reasonably good PC's with SSD drives and they work fine, both running windows 10.
However we both get an issue when opening our download folders where it doesn't display the folder contents immediately, and the folder stays blank for a few seconds with a "working on it" message before the folder contents are displayed.
Is there anyway to speed up the process? Is it a caching issue or something.
Thanks
Right click on your download folder and goto "Customize" tab and set it to "General Items" and apply to all sub folders
Click ok and you should be sorted
Kimbie
Thanks will try that, there's probably 80 odd files and subfolders, not a huge amount, or is it?
No my download folder is a lot worse, but if its set to something other than general items it tries to get all the meta data from the files before displaying them
Move everything from your downloads folder somewhere else. Then download something and open the folder again. Probably going to be a lot faster than having a lot of items in there. You don't really need to keep everything downloaded in their though. Sort your data out properly. :)
