Worth upgrade CPU due to GPU/Monitor upgrade?
22 Dec 2002
Teesside, UK
Hi,
Should I upgrade my CPU from a Core Duo 6400, as I'm about to upgrade my monitor and Graphics card. CPU/Motherboard would need to be less than £250 combo
Currently using the following
Gigabyte DS3
Intel Core Duo 6400 (overclocked to 3000)
Nvidia 8800GT
I'm getting a 24" monitor along with a GTX280. I'm just not sure if I need to upgrade my CPU to support this. This will be my last purchase for a few years. I'm running Vista 64 with 4gb Ram.
I'm a keen gamer so I'm thinking 2 years ahead in regards to gaming at high rez with AA, as well as demanding games from the last year.
On a side note I've heard that my existing 8800 could be used as a physx card. I'd need a new motherboard for this so again I'm just not sure if it's worth it along with the CPU upgrade.
I upgraded from a Gigabyte ds3 board and 3.3Ghz C2D to the system in my sig and it's made a big difference. What RAM have you got at the moment?
I'd go for a Wolfdale E8500 (clocked to 4Ghz+) and an Asus P45 board along with some new RAM(depending what speed your current stuff is) and HSF if you need it.
Thanks for the reply.
After checking my order history here is the exact ram I'm using
GeIL 4GB (4 x 1GB) PC2-6400C4 800MHz
The Asus P5Q was the board I was considering.
Any idea if my current Ram will work and allow the overclock to 4ghz mark, as £250 would be my max to spend on any additional items.
Yes that RAM will work fine mate, as it's 800mhz you can hit 3.8Ghz without running it out of spec even. (on an E8500 400*9.5 = 3800mhz) It should be good for 4Ghz no problem. The Asus P5Q board is a good choice too, most people reccomend going for the Pro version atleast and the E or Deluxe version if you can stretch to it. Personally I'd go for Asus P5Q-E Intel P45, offers better cooling than the 2 cheaper versions which can only help overclocking.
£238.50 will get you the E8500 and Asus P5Q-E so right on budget, maybe look at getting an aftermarket cooler too if you dont have one at the moment?
Once again thanks.
Referring to my original question the upgrade of the CPU and Motherboard sounds like a good idea. I'll go check that shopping basket now
No problem. I'm sure you'll be happy with the new rig :D
Defently worth getting the new CPU and board as your upgrading your GFX and Screen.
