Depends what he will be using the pc for?
can you name anything that will really benefit from quad?
Im trying to decide, go ahead with my current build i have planned (with a Q6600) Or wait for Penryn?, as Penryn isnt a major increase in performance it may be better to just skip it and upgrade when Nehalem gets here, what does everybody think?
well i know that, but i have seen no evidence thats theres any real benefit going to quad, read fair few reviews on it as well, especially the Q6600, can you name anything that will really benefit from quad?
To answer some questions, the PC will be mainly used for games, and my current one is broken due to a PSU exploding, so i do need a new one ASAP realy.
Thats really usefull info, thanks for pointing that out, i wasn't awear it could benefit (though probably depends which version ?), im running VS 2005 on mylaptop at the moment, and its slow as anything to start up and compile programs.Visual Studio. It will compile different .cpp files on different cores, meaning that multi-core compilation is noticeable faster. You will also get a much more responsive and reliable computer while it's compiling and/or debugging.
Q6600 then![]()
His PSU just went so i would spec him a lower power chip, and the Conroes are faster in games because they clock higher. I see no reason at all a gamer would pick a quad just now over a faster clocked dual.
Show me some benchmarks between a 4GHz Dual Core and a 3.6GHz Quad Core please....
in programs which use only 2 or 1 threads, the dual core would be unnoticably faster (as in probably like 5%), but in ones which use 3, the quad core would be up to 50% faster, and in ones which use 4, up to 100% faster, there has being loads of topics about this.You dont need benchmarks to know 2 identical architechtures, but one clocked 10% faster, the 4Ghz one would be faster. Because its only half the cores it will use significantly less power and give out less heat doing so too.
