- 6 Sep 2016
I have a 24" TN panel screen, 60hz, 1920x1200
With new GPU's with faster refresh rate support matching monitors (freesync/g-sync) and with different backlight (less power less heat) and different panel type (ie IPS) would it be worthwhile changing my monitor as well?
I don't think I'd want higher resolution as that means greater demand on the GPU (but I guess with higher res it means you don't need AA)
