Worthy Upgrade?
8 Sep 2005
Chichester
Would this upgrade be justifiable?
And am i right in thinking i can use x2 on my current board by flashing the bios?
And before anyone says, yes, i am aware my board doesn't support SLi, im gonna perform the mod to allow this though.
Current Spec
DFI LanParty Nf4 Ultra-D
AMD64 3200+
1GB Corsair PC3200XL TwinX (2x512mb)
Inno3D 6800GT
Upgrade Spec
AMD64 X2 3800
2GB Corsair PC3200XL TwinX (4x512mb) or 2GB GeIL PC3200 Value (2x1GB)
2x Inno3D 6800GT SLi or 1x 7800GT 256mb
Personally, I say keep the CPU you have for a while, and grab a cheap 7800GT or another 6800. maybe more ram.
If you want the PC to last for a while, M2 is just around the corner, and the reason I holding off dual core.
Get the X2 3800+
then
Sell your current card & get the X1800XT 256 at just £194.95 +VAT
Much faster than 6800GT SLI & much faster than the 7800GT .
I don't want an ATI card :p never have liked them.
If i upgrade only my graphics card and ram won't my cpu be bottleneck?
Lets say these specs:
3200+
7800GT
2gb ram
Well, depends mate.
Most games now are a lot less CPU intensive, also you can clock the 3200 a bit... especially if its a venice. My venice 3000 is at 2.8GHZ... so you should be able to go a bit higher.
Dual core is great, but games dont need it that much at the moment. I say grab the ram and card... OR wait a bit and grab the new geforce when that comes out...
If not going ATI then get...
AMD64 X2 3800
1x 7800GT 256mb
Should be a nice upgrade, what with UT2007 & other dual core games coming.
