Worthy Upgrade?
12 Mar 2006
In The Sea Of Leveraged Liquidity
Hey,
Would like some new toys to play with but not sure if it's worth the outlay.
Thinking about this lot:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-075-LG&groupid=17&catid=949&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=GX-210-SP&groupid=701&catid=56&subcat=1403
http://www.overclockers.co.uk/showproduct.php?prodid=CP-272-IN&groupid=701&catid=6&subcat=793
Is there a certain cpu which is better to go for? Can you get 4Ghz out of that 7500?
Cheers for any input!
Edit: Just noticed i would have to swap out the ram would'nt i? The 5300 might be a better solution....:confused:
Looking at your sig. you already have a 20" Dell monitor, so do you really need to go up 22"? what is wrong with your old one?
I'd suggest saving your money and just geting a new gfx card. :)
Put the money to a later purchase as mentioned already for mobo/memory/cpu.
Yeh i thought GPU only might have the been the best upgrade option...think i'll order myself a nice 4890 then! :)
