Would this combo work ok ?
yep yep mate, will have to set the ram speed manually thou, well i imagine anyway. most motherboards boot ram that is faster than 667 @ 667 regardless.. but bar that should all be good :)
What do you mean by set it manually, as in set the ram timings in the bios and the voltages ?
voltages and timings should be okay, its the frequency :) so just head of into the bios, look for the RAM frequency page, and set it to whatever value is appropriate (so for stock FSB/CPU speed 1066mhz) and it should be all good mate :)
