WOW - L60 Higher Spells
7 Feb 2004
I noticed that for some of the Spells you can get higher Levels other than the ones that you get trained for.
From books and drops apparently...
Is this true?
Is so what are the warlock and warrior ones called?
they drop from AQ20 bosses, tomes etc of the next rank up of 3 spells for your class. Useful for dps classes but most healers dont use top rank heal spells mostly anyway.
Warrior books are called Manuals ( Eg. Manual of Battle Shout VII )
The 3 different books are :
Manual of Heroic Strike IX
Manual of Revenge VI
Warlock books are called Grimoires ( Eg. Grimoire of Shadow Bolt X )
The 3 books are :
Grimoire of Corruption VII
Grimoire of Immolate VIII
The shadowbolt rank 10 book is great if you have MD talents (10% more shadow damage) as you REALLY notice the difference damage wise. If you dont spec for that particular type of damage its abit crappy tbh due to it having about 20 more damage than rank 9 untalented
well i bought multi shot V and the difference is quite extensive (especially being MM spec) was about 300. some guy is looking for aspect of the hawk for about 250.... ok so i have gold to burn.
The only one im missing, and the one i want the most... go figure :(
Will crits be crazy with my new Xbow, even though I dont have Barrage
i have hawk bonus though with DS set so its that extra bit more.
And multi went from +138 to +173 for me though i am still MM spec (currently 2-31-18) at which points the crits really are quite nice.
You might wanna try Agility build, since you have decent gear and compare the two with eachother. The agi will give you that extra bit of RAp aswell, which should add some more. I always hated the MM tree, but soo wish I could have barrage :P
