WoW Running badly?
Permabanned
14 Apr 2012
Hi guys I always thought World of Warcraft was heavily CPU dependant so I thought my new 3930K with more cores and threads would help my performance along side my 780ti. However I'm getting this sort of CPU usage whilst playing the game http://s10.postimg.org/45yt9ij89/Capture.png.
Standing in Ashran with hardly any people I can't face one way and get solid FPS and then if I turn my camera towards about 5 people I dip into 40 FPS which isn't pleasant anyone know why this is?
Whilst playing through the expansion I was at a solid 90-100 FPS now this? :(
I dont think it will use any more than what the i5 had.
So maybe the 600MHz speed difference might be the reason, but surely a 3.8GHz i7 Hex core wouldn't struggle.
I am fairly sure WoW prefers clock speed to cores, although I vaguely remember someone saying the engine was overhauled somewhat for the new expansion?
Motherboard drivers up to date for the chipset?
That chip shouldn't be struggling at all, WoW wouldn't bring a chip like that to it's knees, the core speed is OK.
I'd be looking at making sure drivers are up to date.
With the 3930k being a 2011 chipset, did you do a fresh install of windows?
How many cores does WoW actually use?
1 Main thread + 2 lesser threads (that can happily share a core).
Runs fine on dual cores, but as stated better off with more clock speed than more cores.
A 3930k should be plenty quick enough though.
Exactly the same problem as yours, albeit my pc is less powerful (r9 280 , fx8320).
Regards.
You playing in Fullscreen windowed mode? That massively lower frame rate for some reason, try switching to full screen if you are.
This. Funny thing is an overclocked Pentium Anniversary Edition CPU would be faster than a stock clocked i5/i7 in WOW :D
Well I agree Marine but surely my 3930k should be fine for the job my CPU is hardly working when playing wow.
MMO (and RTS) are general the type of games that are THE hardest on CPU. It is unfortunate that for WOW, your 3930K's 6 cores 12 threads, only 2 cores are being utilized, making it only a fraction of your 3930K's full power being used, and not really anymore faster than a SandyBridge i5.
Also the low frame rate in mmos with the thread limitation aside, it could involve other things as well such as the directx overheads and how the game engine is coded. For example one of the mmos I use to play, it has a feature which can hide all other players except for the ones in your party (to reduce the lag and stress placed on the systems)...and at world boss, when I hidden other players except my party members, the 4 cores on my overclocked i5 would hit pretty much 90% most of the time...but when I press the unhide other players button with like 50 other players pop back in the screen, frame rate drop to hell, and even CPU usaged dropped down to around 55-60% as well, despite I should still be CPU limited rather than graphic card not being fast enough.
Hopefully with the development of Mantle and dx12, it will address this issue, assuming that both or either would become mainstream enough for all future mmos adapting the use of these new APU...however, it wouldn't help old games with dated engine such as WOW.
In the ideal world Blizzard should make a modernised WOW that's got a new engine built from the ground up (not just tweak/modify the existing engine) that would use 8-12 threads and transferr all players' data across, but it would be too much of a hazzle, and Blizzard most probably see it as a poor investment vs return, as there's not really enough new players joining this dated mmo anymore.
Poorly written addons can kill any systems fps, update all the UI addons everything, turn everything off and see if the fps improves and then turn things on one by one to see what has effect.
Regularly deleting the cache folder keeps my game running smoothly too, i dunno why this helps but its always suggested when people have problems in game and works half the time. I think its summat to do with files going corrupt in there easily.
If drop my CPU speed from 4.4 to 3.8 i dont really see an FPS drop, maybe its down to addons like Gothis says.
