WoW trial question
12 Dec 2005
I'm downloading the WoW trial client at the moment, when I came to install it, it asked me which version of WoW I wanted to download and install, I selected normal WoW. Is this right or did I need to select WOTLK as this is the latest expansion?
Cheers
If it's your 1st time playing i'd say the Normal is fine, as you won't reach The Burning Crusade content until 58 and you won't reach WOTLK until you hit 68 :P
I'd imagine with the new Downloader it will just download the extra stuff on it's own anyway.
I downloaded the WoW client which was 3GB, then a patch that was 5GB now I've got to download another 7GB worth of stuff. It's put me off playing.
