First install burning crusade if you haven't already and download the automatic updates. Then go to account management and you will find an option to enter your burning crusade key - this will update your account.
You will need to add your normal key first to move the game from a trial to full version, then add *** BC key.
your trial account IS a normal account, just time limited. so wont accept a normal key.. you dont need it, as you already have it. just put in the BC key and all will be good.
you still need a wow key to upgrade the game to the full version, its exatly what I did myself.
Can you log into your trial account via the wow euro login page?
No I can't...What does that mean?![]()
If the keys you bought are ok then all i can think is that you downloaded and created an American version/account. The euro and american versions are not cross transferable and are treated as totally separate concerns when it comes to customer service and such.
LOL owned
No big loss if you're < level 10 anyway. The guild bank will help you out a bit with bags and stuff that the higher levels no longer need.
