wrong info on cpuz?
17 Oct 2005
i have an E2000 i have just installed
loaded up optimised settings in bios
200 fsb *11
but when i load up cpuz it initially says 11 times multiplier then about a second later says it is 6 times
rechecked the bios and it still says 11 times what is right
is there another program i can check it with
or is the bios wrong
its speedstep, it reduces your cpu multiplier to save power, then restores it back to normal when it is needed.
it can be turned off in the bios by disabling C1E and E1ST
i have tried changing the setting in the bios
the multiplier changes ok
but the fsb stays at 200 no matter what i change it to
if i go back into the bios it shows up at what i set it at
ie 250 but still showing 200 in cpuz
