Wrong memory speed msi bios
19 Feb 2015
Gloucester
Noob question, my new build shows the 3600 memory as 2666 in the top left, yet the XMP shows the correct speed and timings. What do I do?
Hmm, sorry, I could be wrong there - Rebooted my X570 Tomahawk to check, and it showed 3600 in my current (manual settings) profile AND when I switched to XMP.
Have you saved your BIOS changes?
I'm really perplexed; I just built this system this evening and everything in the bios is the default settings. I seen that memory was showing as 2666 and went straight to XMP to correct it, but it's already showing as the correct speed and timings..
what voltage does the ram need to run at 3600 Mhz?
Might need to increase that...mine needs to be manually changed to 1.35v for xpm speeds
You've got the same MB as me but I notice your bios is not up to date, you are on A00 and I am on A30 - suggest updating your BIOS and see if that fixes it.
Would it not make more sense to update the bios to the latest version and see if that fixes the voltage instead of doing it manually?
I've never touched the voltage manually on mine just left it to the BIOS when setting my XMP profile.
The OP's bios as shown in the original pic is the initial BIOS release and one of the later one's does state 'Improved memory compatibility.'
