Am building a new loop to include a new pump /res block - one of ocuk built Pump Combo's combining a d5 pump and ek x- res.
Finally sorted all the bits needed (all through ocuk
) and was looking to drain old loop + dismantle as required + add new tubing, 2nd gpu and extra rad + new pump-res , this weekend.
Started last night by taking the cooler of my 2nd 7950 and fitting the new block - no probs.
Decided that tonight would fit together the mounting bracket which enables one to attach the pump/res combo to the case.
Came with a sealed (EK) plastic envelope containing 6 screws+ 6 washers + 2 nuts + 4 vibration fittings + one allen key - looking professional etc
BUT
Vibration fittings + washers = good
Screws - NOT good - too small for the holes and nuts.
Allen key - NOT good - too big for the screws
Extremely irritating - new build will now have to wait for at least another week as even if ocuk are able to send me the correct screws (which I am sure they will )before the weekend I will not be able to get on until Saturday at the earliest.
Not pleased with EK
Ah well - whinge over
BUT
Not pleased with EK
