»» Routers that are known to work with Tomato:
* Linksys WRT54G v1-v4, WRT54GS v1-v4, WRT54GL v1.x, WRTSL54GS (no USB support)
* Buffalo WHR-G54S, WHR-HP-G54, WZR-G54, WBR2-G54, WBR-G54, WZR-HP-G54, WZR-RS-G54, WZR-RS-G54HP, WVR-G54-NF, WHR2-A54-G54, WHR3-AG54
* Asus WL500G Premium (no USB support), WL500GE
* Sparklan WX6615GT, Fuji RT390W, Microsoft MN-700
This will not work on Linksys WRT54G/GS v5 or newer WRT54G/GS routers.
No I'm open to change but I'm just trying to find out what the advantage would be over the firmware I already have ... the answer seems to be there won't be any advantage for what I do as far as I can see.If you don't want to change, you're not forced to...
If routing of traffic was quicker, signal strength stronger, connection distances increased then it might be worth it but as it is I can't see any way it would benefit me.
, I always found the original firmware (with exception of the torrent problem) fine and my router went for years on end without having to be re-booted.
