X-Box Series X - Audio via 5.1 PC surround speakers
22 Sep 2008
Liverpool
Hi,
I've got an ancient 5.1 surround sound system which still works brilliantly, which I'd like to connect my X-box to.
PC 5.1 Surround Sound Speakers
It seems like the common approach is to get some sort of HDMI audio extractor that sits in-between the Xbox and the Monitor I'm using, and then use that to then connect to the 3x 3.5mm speaker inputs.
I'm nervous of spending around £100 which will get me the job done, but with any sort of lag, or cause issue with the screen.
Does anyone have any experience of this or have any guidance to offer?
Mike
Even if it does work, you might not get surround audio passed through correctly if the speaker controller uses an older format like DTS. I would make sure you have a good return policy just in case it doesnt work how you are expecting
