X-FI Elite Pro a worthwhile upgrade from Audigy4 Pro?
28 Jun 2005
Behind you
Hi all,
As subject says. I do everthing, music/DVDs/games. Will I get much better sound on the X-Fi Elite Pro (speakers in sig) or should I stick with the Audigy4 Pro?
Thanks
It should do but it depends on your speakers i think. I went froman audigy2zs to the xfi and i noticed a difference
I think the Audigy4 Pro is better than the Audigy 2zs, but I was told that the Audigy4 Pro had a better DAC than the X-Fi which makes the sound clearer, is this true?
X-FI Elite Pro has better DAC`s than any of the Audigy cards.
Have used all the Creative range and X-Fi Elite Pro is the best Ive listened to so far. Turn off the DSP effects and gives you very clean sound.
Works fine on P4 Chipsets but however people with nforce chipsets seem to be experiencing problems.
