- 17 Mar 2006
Last week I took advantage of the O/C's This week only offer on the X-Fi Fatal1ty soundcard.
Ordered Friday afternoon, arrived Monday morning. The usual speedy delivery from Overclockers.
So far so good.
Rushed home that night, unwrapped everything (although some things looked like thy'd already been opened? - I was too excited about my new gadget to worry, perhaps I should have taken more time to look over everything).
However, the card itself and the front panel looked ok so on with the install.
Connected everything up, taking heed to make sure the IDE type cable was connected the correct way round. I used a floppy drive power connector to the front 5 1/4" drive panel.
Windows (XP SP2) detected the new hardware, I installed as per the instructions.
Rebooted and yipee sound out of my Medusa's
I then thought I'd try connecting the Xbox 360 to the front line-in 2 audio to check it out and..... nothing. The only thing that worked was the Remote. I checked every setting in the sound settings, line 2 unmuted, volume up, the front volume control on the panel was switched on as well.
Bugger I thought. It must have been the power connector as I hadn't used the one supplied with the X-Fi card. So I disconnected everything and used the supplied Y-power splitter and connector.
Now the remote doesn't even work!!!!
I may as well have saved my money and brought one without the panel!!!!
So far so good.
