Okay, I have an HTPC currently using onboard HD Sound.
Sound is output using ASUS motherboard SPDIF header and module, through optical Toslink to 5.1 Receiver.
All works, DVD passes 5.1/DTS through to amp, games etc. pass PCM to amp.
My problem is that games' sound stutters/breaks up quite badly even with E6300 CPU and 2gb ram. I figured the best way to fix this is with dedicated sound card, rather than using onboard. After doing some research, the X-Fi gamer seemed a good bet, and ordered one yesterday.
I have just received the card (not installed it yet), and find it has an optical out on the back, and also an SPDIF header on it. Which am I best to use? - the optical out on the rear, or plug my ASUS SPDIF module into the header, giving me the option of optical or coax (if the module works with the card).
Thanks guys.
Si.
Thanks guys.
Si.
