X-fi randomly emits screeching noise
13 May 2006
I'm onto my second Creative X-fi fatal1ty now, both have the same problem. All of a sudden, sound will cut out and be replaced by a loud screeching sound, even if I disable the device in device manager, the only way to stop it is to reboot the PC, then it'll work fine again, sometimes for 10 minutes, sometimes for 10 hours. It happens in entertainment mode playing music or watching a video, it happens in game mode during TF2.
I've noticed this crops up in the windows logs around the time it happens, however I'm not 100% sure it's related.
IRQARB: ACPI BIOS does not contain an IRQ for the device in PCI slot 2, function 0. Please contact your system vendor for technical assistance.
I believe the X-Fi is in slot 2, I do not have any other PCI devices installed.
I've messed about with the ACPI settings, PCI PnP and other PCI settings in the BIOS to no avail, but I'm not really sure what I am doing to be honest :(
Does anyone have any suggestions? Creative support have been no help whatsoever :(
I have the following:
Asus M2R32-MVP Motherboard
Athlon 64 X2 5200+
Corsair 2GB DDR2 800MHz/PC2-6400
PowerColor ATI Radeon X1950 XT PCIe
Creative X-Fi Fatality
Running Vista x86
Thanks in advance.
This is a well known fault...it covers varius motherboard chipsets. Apparently my motherboard has the bug with the X-Fi, but I have not experienced the amount of problems other prople have had. Except the soundcard disappeared a couple of times probably twice in a year.
I'm struggling to find anything that confirms my motherboard is the issue, I've only found the one article where a guy says his X-fi works fine on his M2R32-MVP.
May try a bios update, see if that fixes it.
Cheers.
Hi Danners
I have the same problem with my card i have already spoke to creative about this and they said it is a well know problem with Nvidia mobo's and will take my card back and flash it with a custom firmware that will fix my problem.:)
Thanks, I've read that there are a fair few issues with X-fi and nvidia mobos, however the M2R32-MVP has an ATI chipset so I'm not sure if that applies with my issue.
Will keep persuing creative about this anyway.
This is a hardware or software problem imo and creative are not being honest about it had the same on my xfi xtreme music on an abit ip 35 pro on xp what fixes it is simply changing modes when it happens which is very rare.
Maybe it is a software issue ? something we all have installed and recently updated I was thinking (scratches head)
Annoying but not as bad as the snap cackle pop we had on the old audigy cards I suppose.
Unreal that in this day and age we still have no properly working sound cards without issues.
I got the same issue with my old Audigy 2. It worked fine for years than one day, 'squeal of death' (Google it) every time I fired up Oblivion.
Replaced with X-Fi XtremeMusic and it works fine. Given that my Audigy worked for so long without a problem, I'd say it was the card dying.
Well I've run the card in XP for 2 days with no problem what so ever, install vista and sp1, and within 10 minutes of gaming, the sqeak of death is back. Clearly a Vista problem and Creative seem to think it is everything else but Vista.
:mad:
