This is just a heads up for anyone using, or looking for a calibration device.
I bought my X-Rite i1 LT a few years back, and all of a sudden, it has failed. It has had very little use, maybe 2 calibrations per year at the most. When I contacted X-Rite, they said (and I quote) "The i1 display LT / 2 used to have organic filters inside which are aging with the time, and it can lead to color shifts after some time (4 to 5 years, depending on the storage of the device)."
What that means, is no matter how little you use it, the device will degrade and fail. Anyone looking to sell on their device, is potentially selling a ticking timebomb, that will fail at any time. Anyone looking to buy a device, would be well advised to steer well clear of used devices, as again, they could fail at any time. If you happen to buy old stock, you could be buying a device near to the end of its life, and have no way of knowing.
I personally think it was well out of order, to sell a device that they knew would degrade to the point of failure, without any warning or notification. To me, any device with organic content, no matter how small, should be clearly labelled with an advisory warning, that the device will fail after a finite period of time... even to the point of having a "use by date". I know I wouldn't have bought a device costing £100, if I knew it had this problem.
So beware, make sure you do some thorough checking before you spend money on a calibration device. I know Lacie use the same GretagMacbeth devices, so they might just suffer from the same problem. Apparently, X-Rite devices now use different filters... and you can see why.
