Hi all,
I have a slight issue i hope someone can help me with.
I have had my Connect3D ATI Radeon X1800 XT 256MB GDDR3 PCI- Express card for 6 months now, over the last 3-4 weeks it has developed some issues.
in game i get a lot of strange grpahical errors, hard to describe but its as if the graphics have been stretched into long thin lines, its like screen tearing and flickering polygons. It happens a lot.
Also lately i get a lot of random computer hanging in games.
I have tried various drivers but it still happens in most games.
The screen tearing is very regular. I have tried complete reinstall of windows xp. Updated my Motherboard drivers/bios. I have also tried to lower the speed the card runs at but still no luck.
Normal operation in windows is fine. I have checked the temp of the card and it is around 56c just in windows when running games it goes up to 68-70.
i have also checked the card (and computer) for build up of dust etc but everything is fine.
My computer spec is as follows:
Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (happens on all bios versions i have tried)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
Running windows xp sp2.
I have talked to connect 3d and they suggest i get a replacement.
Before i start the long returns procedure id like to verify it is the graphics card causing these problems.
Does anyone have a good testing process for ATI cards?
If you need any more info let me know. and thanks in advance
