Hey all,
Wondering if anyone can help with a problem i'm having with my gfx card (X1900)
Firstly when playing games most of the times it will be ok, but then i get one part or area which stretches out from 1 point upwards like a big long triangle. Then more usually appear after a while.
LAtely the card has been locking the game up completely, then the screen goes blank like it is in power saving mode but can't get anything to respond, but you can still hear everything working in the background.
Tried using ATI Tray Tools overclocker settings (set to default standard) and using the renderer to check for artifacts, and even at stock speeds ad below i am getting some artifact problems.
Games used are all different types and all have the same problems.
Hope someone can help before it goes in the bin.
Ta,
Ta,
