x1900 noise
Somewhat noisy at startup (as fan spins at 100%) & when fan runs at 100%.
However you can setup what temps & at what speed fans run, so it is reasonably quiet.
What makes is your x1900?
Out of all the brands available, are they all gonna make the same racket?
The conclusion I came to from my scientific test (going to friend's house and listening to his) was that in your average room, it will not be heard. If you have an unusually quiet room, are tuned to noise or sleep next to your PC, then you will hear it, yes.
