Hi,
I used to have a 7800GTX and moved back to ATI with an X1900 XT. I wanted more from the XT so I just opted and purchased from OcUK an X1900 XTX. It arrived today and when I got home from work I changed my card over.
The problem I have is that if I play COD2 with th XTX the game runs for a minute then the screen goes black. My LCD led indicator changes from green to yellow and I have to reset my pc. I can still hear the game in the background but I cant get any keys to work etc so have to hit the reset button on the case.
My old X1900 XT wasnt doing this last night so it must be something to do with the new XTX.
If I run CCC overdrive utility the same thing happens when the temp reaches 79 degrees C. The core frequency has only moved up a few Mhz by this time.
Has anyone else had this problem. I'll phone OcUK tomorrow and RMA it. The card is a Sapphire the same as my XT was.
Cheers for any help,
Chris
Chris
You had a x1900xt card and then went and brought a xt1900xt-x..Why did you not buy a crossfire edition card and run them in crossfire ??
