X1900XT 512MB problem?
23 Nov 2004
UK
When i use ATI Tool it shows the default values for the card to be 500/600 :rolleyes:
I thought these were 625/725 ? Am i doing something wrong here?This is 1 of those days where i think "should have stuck with Nvidia" lol :p
A bit of help would be much appreciated.Anyone got VNC or want to add me to MSN and remote?Ive had several efforts at it with no joy.Got the Voltages to save ok though.
Give up! It's going back in the box lol.Tried countless times to save the clocks in new profile but it wont have it :confused:
Tried 2 different versions but no luck with either.Its probably something really simple im doing wrong but its taken 1/2 my night up already
CS||nuTs said:
Did a Fresh install just for this card,so unlikely to be windows.Probably just me being a ATi nooby.
First, have you disabled the ATI services when using Beta 14?
2ndly what happens when you set *** clocks using the sliders, apply and then save to the profile and then load it?
It stays at 500/600?
If it does try editing them in the ATi Tool config file in Program files.
It WILL work. We just need to find out if its user error or something isn't playing ball ;)
