X1900XT 512MB problem?
Struggling to get it much passed 630/750.Have used the voltage settings suggested by Concorde Rules.I've now installed a 120mm fan blowing at the voltage regulator and temps have dropped a bit.What are the limits on these vards as far as speed/volts go?
Damn some of you lot like doing it the hard way.
With CCC my 1900xt Master card will do on stock cooler 690/800
CS||nuTs said:
Again a very helpfull post.Maybe try to help me solve this instead?
Your attitude is not the best either m8. I would run a benchmark and see if you get a score which u expect. Since u dont have a clue about how to verify that its running at correct speed. Its also totally unnecessary if u just check the performance.
Actually Id say sell your perfectly operational card for a loss and let someone not polarized to one manufacturer buy it.
Have u read about the issues plaquing the 7900 series with a slight bump in overclock? Shocking reliability.
Where do u get this "shoulda stuck with nvidia" attitude from?
Well for starters the thread was asking for help and everyone loves people who post useless info ,dont they? Secondly you do not know me,do not know what cards ive previously owned [9700pro,9800 pro,6600GT,6800Ultra,x800,x850,7800GT] which kind of blows your "Fanboy attack out of the water.
I've ran numerous benches but had not used ati tool to set 1 of these up before so was asking what i should do,NOT "is this performing right"?
Appreciate your input thanks,my attitude is fine although not quite as judgemental as yours.
