Hi guys (and gals if any),
I think I'm having a problem with my graphics card. The following three pictures should explain a lot.
This one occured after I installed ATITool and loaded it for the first time. It hasn't happened since, so I assume it can be neglected:
This one happens when playing Call of Duty 2 (fully patched). It happens anytime between 1 and 5 mins:
The final picture shows ATITool itself. I have left the fan running at default speed, and ran scan for artifacts. Now, a lot of people on other forums say that yellow dots are normal, but I think this might be one too many, the yellow dots just start increasing like rabbits!
However, when I manually set the fan to 100%, temperature decreases to 70ºC and all yellow dots disappear.
3DMark05 and 06 run perfectly, and my computer is orthos stable for 4:30hrs, and prime stable as well. Has anyone else encountered similar problems like this?
I'm wondering whether its a display driver problem, I'm currently using the latest 7.1 drivers. I will install a few other games later today and see if it causes the same problem. I brought the card from here (Asus brand) a few months ago, so it's still under warranty.
Any ideas?
Many thanks,
JP
Any ideas?
Many thanks,
JP
