So have I, take another look.Bennah said:I listed the 580w models not the 360w and 420w.
Your "total current" supplied is the sum of the currents and is flat out wrong.Bennah said:I know. The Tagan supplies 420w ONLY to the 12v. I wasnt on about that in the post that you quoted.
Looking at the post I made, it shows the Make / Model of the psu, weather it has single or dual 12v lines, Amps on each line and the total Amps. Where does it look like Im noting the wattage of the 12v line?![]()
Nice enough, that you posted the link after I made my post...
Anyways, I was only listing the psu details that I could find info on that MG42Maniac posted in the first place.
fornowagain said:Your "total current" supplied is the sum of the currents and is flat out wrong.
Like it says a couple of posts up "the values given for the rail outputs are the maximum for each rail without any load connect to the other rail. You can't use the sum of the currents. Look for the combined wattage for the sum of the currents 12v1+12v2 etc and divide by the line voltage"
Don't think so, the specs say it can supply 420w@12v max that's it any config you like. Split mode will increase stability, that's it. They feed from the same rectifier.Bennah said:The Tagan does supply 40A. 20A on each of the 12v lines when in SPILT mode. When combined then you get 35A on the combined 12v line as it. Switch at the back to change from combined and spilt modes.
nands said:I don't think I am wasting money, the Powercolor X1900XT is currently £239.95 + VAT, but the cheapest 7900GTX is over £300 + VAT. The whole thing is new build so I have not bought the Sonata yet.
nands said:Thanks for the info, Yorkshirepadd. I reckon I am going to go for the Hiper 580 for a bit more peace of mind. As pointed out by fornowagain it definitely complies with the 30Amp stipulation on the ATI website.
Bit of a bummer that the Powercolor cards are no sold out. Nevermind, the Connect3D one will do the same job. Does anyone know if you get any free software with it (or any of the other X1900XTs - I know that Sapphire give you a choice of two games but I am not bothered by their selection!).
fornowagain said:Don't think so, the specs say it can supply 420w@12v max that's it any config you like. Split mode will increase stability, that's it. They feed from the same rectifier.
As for the Hiper. Whats 18+20 x 12, its not 360 is it.
nands said:djjuk, it is good to hear that the combi I have selected is being run, and enjoyed, by someone!! I will get that tomorrow (bit of finance to sort first!)
Rolleyes? I'm trying to show you that the each rail current is not the same as the total current available. I wouldn't want anyone to buy the Tagan thinking it can supply 40A when in reality it's only 32A. Wattage and current are two sides of a three sided equation, they do not exist in isolation.Bennah said:Why are you showing me this? Trying to pull one over me ? Whats the point![]()
Im not saying your figures and what not are wrong. Im not going on about wattage. Im going on about Amps on each line. The specs say that in spilt mode the Tagan can provide 20A on each line. Thats what I said and you started to pick holes in it. Simple as. I think its enough of this anyways.
If you wanted to make a point, you have done it. End of.![]()
