Ive recently got a x1900xtx running on a 19" OPTRONIX LCD MONITOR OP-9005L.
Ive got some wierd phase issues when running in 1280* + resolutions(using higher res with a higher end card). There seems to be a wobbling of fixed lines and images.. as if the phase is wrong.. altering of the phase settings slightly improves it but the problem is still there. Yet its fine @ 1024*768
The connector is DVI out but throught a VGA converter that came with the card as the monitor is VGA out.
Anyone got any suggestions of what a cause/fix would be?
Many thanks...
Many thanks...
