X1950 pro causing crashes!?
24 Nov 2006
Altrincham
Hi,
I have an X1950 pro and while playing COD4 and running 3D mark my monitor goes to standby mode and can't be woken up until a reboot although my pc remains on.I am using xp with 2gigs of ram and a quality 600w psu and also have the latest drivers installed.
Does anyone think the ultima gts package on ocuk would be a worthwhile upgrade for me or should i go for the gtx ultima without the monitor etc???
Jonny
Mine used to do exactly the same until I done two things:
1. Used rivatuner to have the fan on 100% all the time.
2. Bought a PCP&C PSU.
Have a browse of the Sapphire forums (my cards manufacturers) and it's a common problem.
Thnx for the fast reply,
I'll try rivatuner but i'm not sure what a PCP&C PSU is.What do you think about the Ocuk set ups?
Jonny
