I'm looking to upgrade my GPU so I can play GTA IV Maxed out and also a lot of the newer games.
Current spec as below (the important bits)
* Core 2 Duo E8400 - 4050 Mhz
* IP35 Pro
* 2GB Corsair Cas 4 DHX 6400
* Sapphire X1950 XTX 512mb
I've been chatting to 'Loadsamoney' about cards on MSN but I've still not decided what to get
The ATi HD4870 looks a good choice, but the warranty seems a wee bit short and I'm not sure whether to get the 512mb or the 1024mb version..
Are Nvidias offerings better?
What do you recommend? Being an ATi fanboy all my life doesn't help matters though
EDIT - Important stuff! I will be gaming at 1280 x 1024 on my Viewsonic VX922.. so is 1gb of ram required on such a card?
* IP35 Pro
