I've just recieved my shiny new X1950XT at work, and opened up the box to check i had all the bits i need.... and guess what? It doesn't come with a PCI-e power adapter :O
So, looking around i found instructions on building a 2x4-pin molex to 6 pin adapter out of bits of dead PSU which i can find at work - so far so good...
What i'm not sure about is whether my PSU is going to be man enough for the job - the instructions recommend a 450W PSU, and i have a 430W Antec Truepower. Bearing in mind i'm using an Asrock Dual-VSTA mobo with C2D 6400, 2 SATA drives, 2 optical drives, several fans, and 1GB of DDR1 ram, am i going to be able to use my current PSU? Nothing is overclocked at the moment, it's all at stock speeds.
Otherwise, i guess i need to splash out on a new power supply as well! Hiper Type R 580W looks pretty good value - any other recomendations if i do need to buy one?
Cheers
Cheers
) cracking cards those for the prices, will cut through everything for a good while yet.
