thay do metal work for projects and other things so thay got the big and small cutting machines to make it all i need to do is give him the numbers (bring my mobo and heatblock) he get it done in less then an 1hr
be back tomoro (friday with my new water plate that screws on to it)
i am going to use the coolmasters trident as i give up trying to get the coolmastesr 6mm/10mm pipe fitted to the 6mm/7mm connector kit on the TK water block
one thing i found intresting on the coolmaster it has Self Stopping connecters that plugs into the tank/pump unit so when i unplug the pipes and the front unit stays sealed quite cool heh
