Are the core's supposed to be so different regarding temperature?
CPU is under a XP-90C with AS5 clocked to 2.5GHz using default volts and the idle temps using "core temp" are 44°C and 34°C full load is 59°C and 51°C, I've reseated the HS twice now and have the same results.
Is this normal? Core temp wrong? Smart Guardian reports CPU temp as 40°C PWM IC as 52°C and chipset as 46°C
I'm confused
I'm confused
