X2 4800+ from Overclockers
Will let you know, just ordered one and one of those AGP ASRock mobos cos i screwed my neo2 plat up :P
arrives saturday
I got a 4800+ from a competitor and it clocks like this: stepping ccbwe 0604tpmw
and this:
Damn those are some nice temps there man!
Got water meself cant wait to see what I can get out of this chip. Playing the waiting game with the delivery guy atm :D
On the Expert & Venus you need to add 8-10c to whatever smart guardian is telling you as the temp sensor on these boards is a mile out.If you go into bios and under health monitoring it lets you alter the temp sensor so it's best to add 8-10c then it will read correct in smart guardian.
I know I have done that already & has been ajusted, but i thought you might like a pic of my cooling:
There is no way those temps are right, I would get another proggy if I were you. It is impossible that you are not in your 50's or more with a stock cooler. You may damage your chip.
I think all those thinking that those temps arent correct, need to get themselves a X2 4800+! Mine, after hours of gaming, sits at 36C with a mobo temp of 34C checked by hardware monitor onboard the mobo and various software.
It is one fine cold chip! Mine is cooled by an XP120!
What temp reading are we meant to be looking at though. In speedfan, I have 3 that could be the proper reading, I have Temp 1, Temp 2, and Core. The first 2 being around 40C load and the 3rd at 30C. Which do I read as the correct, true core temperature?
EDIT: bearing in mind I have water setup.
those temps are right, smartguardian has been ajusted to and i have good cooling, you be surprised x2 cpu's can go upto 70-75c in temps, just on amd hsf.
I use to have that motherboard you got in your sig & hsf, very good boards, inc. your artic freezer, but theres not much difference between the cooling i have and your arctic freezer.
