- 30 Nov 2011
91C is the maximum although you'd want to stay under 80C really because don't forget it will be a lot warmer when summer comes.
A watercooled system should be better if you're planning to overclock much higher but 60C is absolutely fine.
+1
anything under 80C is safe - I've got a 3930K running at [email protected] on air that in normal/high use hits low 70's and only on a warm day running a full system stress test (CPU + GPU) does it hit 80
watercooling would be if you wanted to start looking at close to 5ghz
