x800GTO help :(
15 Sep 2006
Edinburgh
hey guys ive just got a ati x800GTO agp to replace my old nvidia geforce 5900xt
i how ever have a problem and am beginning to worry if i have a faulty card...
any cat driver 6 series will not function correctly eg latest driver 6.8 installs but my comp acts like theres no drivers installed or if i install 6.5 i get a blue screen of death just as windows xp pro should be appearing...
how ever 5.1 and 5.5 cats work perfect almost and give me performance id expect by almost i mean bf2 has problems with shadows and a few wee glitches.
i went into add remove programs an removed the drivers then i booted into safe mode and ran cab cleaner and driver cleaner pro i then shut my comp down and installed the card then let it boot up normally and installed the ati drivers then i had that problem the 6.8 cats were the first ones i tried :(
edit : i tried the omega drivers based on cat 6.7 last night and they didnt work either :(
arg still no luck its just like theres no driver installed but it installed fine :(
edit: just found out that theres a common problem with drivers above 6.4 on my kt400 chip set so gonna try cats 6.4 that should fix it in meantime i hope :P
thanks for the help :)
