X99 Build for Music Production
23 Nov 2015
I'm looking for some opinions on this X99 build that I would like to overclock to the highest safe level and also keep the noise level to a minimum.
Below is planned build list -
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor
CPU Cooler: Corsair H110i GTX Liquid CPU Cooler
Motherboard: Gigabyte GA-X99-UD4 ATX LGA2011-3 Motherboard ( or UD4P version )
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: Corsair RM750i 80+ Gold Certified Fully-Modular ATX Power Supply
Case Fan: Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm Fans
Any advice would be very appreciated
Noodlez
First thing would be have you looked into compatibility?
i last did one like this with 1156 was first out and i went threw 3 motherboard until i found one that was ok by the OS. also will the gpu work with mac OS?
i last did a hackingtosh with 1156 was first out and i went threw 3 motherboard until i found one that was ok by the OS. also will the gpu work with mac OS?
Hi thanks for you advice,
So far what I understand, UD4 board works fine under Yosemite following many successful X99 hackintosh builds including Bob Roche on Youtube which he also uses Unibeast/Clover but unfortunately the UD4 has been discontinued and replaced with the UD4P which is cheaper and improved, But I haven't seen anyone using this with a X99 Build...:confused:
If you went with the corsair AIO you would have to change the fans because the stock ones are crap and loud, so go with air. I know next time I rebuild I will be leaving AIO for air.
Ok thanks guys,
I was wondering though, will an air cooler be just as good to keep the temp down compared to a water cooler as I'm gonna overclock the 5820k?
Many Thanks
