JasonM;My thoughts / brain dump on components!
 1) Kingston make some of the most reliable memory said:
			Thanks Jason, only two items on your list ended up in my basket, namely the WB black drives and the Samsung Pro SSD. I do like Kingston, their memory does seem good,and their CF card reader is by  far the best I have tried, on this occasion however I went with the TeamGroup Elite 32GB. I was going to try the Gigabyte MB but they were out of stock when I ordered so went with the Asus Delux, if it lasts half as long as my last Asus board I'll be very happy!
Hi BussError, thanks for your reply, its interesting that you built something similar, I'm hoping that I have made the right choices. As well as the two internal WD hard drives I also use WD external drives as an extra precaution and back up. I'm not sure I will trust the SSD completely but hopefully I will always have a backup (or two) or most images before I even start to process them.
I went with the Nvidia 970 Strix partly due to its passive fan when not under load but if needed it should still be capable of running some interesting games and simulations if I so choose.
My monitor is pretty good, I upgraded that a year or so ago to a Dell UltraSharp U2413 61cm (24') PremierColor LED, very pleased with the way it renders colours, it seems very accurate and perfect for my macro work with plants and insects.
Adrian
