Xbox 360 controller in pc usb sound problem!
17 Mar 2004
Gloucester
Don't really know where to put this but I just got my new computer with windows vista and vista is causing big problems. I installed Pes2008 and want to us my ps2 controller, I have the old joytech ps2 usb adapter but the software isn't compatible with vista and i can't find any vista drivers. So i thought I would try my xbox 360 controller but as soon as I plug that in my sound distorts (the sound is fine before) and i have to restart (and unplug 360 controller) for the sound to return to normal! Does anyone know what is causing this? I'm running vista 64 bit with the creative audigy soundblaster se 7.1 soundcard but i'm using my very old creative inspire 5.1 5300 speakers. There's also an issue with these as i can only get the sub and the front two speakers to work. Any help would be welcomed, thanks in advance!
This is not much help, but I have Vista 64 and a 360 controller and all is well. In fact I have never had a problem with it. Have you tried to run the PS2 USB drivers in XP SP2 compatibility mode?
