Ive just ordered a 120gb hdd for my 20gb xbox 360,ive also ordered a transfer cable,are there any good guides about to show a noob how to safely transfer my gamer tag,saves,map packs and games ive bought and saved on the 20gb to the new 120gb ?
great , it seems the transfer cable which ive now read should be avoided at all costs has changed my 120gb HDD into a 16gb flash drive,the xbox wont recognise it if its slotted in but will if its connected via the transfer kit and i cant seem to fix it ,thats 35 quid down the drain![]()
nope , some cheapo off the bay![]()
it is able to be reformatted and changed back to 120GB though. i dont see why you didnt go via typical game shops and get it for £15 for the harddrive transfer kit??? why did you go to ebay and spend £35![]()
stupid cable
Sounds like the 360 thinks it is a external drive, go to memory in the settings options and see if you can remove the 360 software from your hard drive while it is connected via the cable
