Er... no. They are RGB Scart sockets.Nymins said:All of them basically say "RGB enabled scart sockets". Is this the individual red, green and blue plugs that you plug the component cable into?
The TV would upscale (not downscale) a 1280*720 signal to 1440*900. If the 1366*768 has VGA input then get that as the 360 can output at 1360*768 via VGA.Nymins said:Also, what resolution is the best out of the three? I have read that the 360 needs to downscale 1440x900 to the closest resolution of 1280x720 (720p). So i was thinking that the Goodmans LD1928w would have better picture since its resolution will still be downscaled, but not as much as the other two.
